Carter Carburetor Identification - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    Hi,
    I have this old Carter and I don't know what car it goes to, so I'm looking for some help. The only numbers on it are on the top and they are: 6-1672.
    I have also included some pictures.
    jerry
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Carter Carburetor Identification
    Based on the throttle arm, fuel connection, rear vacuum fitting and the secondary air valve weight, I'd say it looks like a early Chevy or Corvette WCFB single quad application model.Stu Fox
    • Steven B.
      • June 30, 1982
      • 4017
      IIRC, which I usually don't, it was used on 250 HP 327 and I think '58-'61 single 4BBL 283.
        • 43290
        Originally posted by Gerald Coia (11656)
        Hi,
        jerry[ATTACH=CONFIG]47156[/ATTACH][ATTACH=CONFIG]47157[/ATTACH][ATTACH=CONFIG]47158[/ATTACH][ATTACH=CONFIG]47159[/ATTACH]
        Jerry-----
        As far as Chevrolets go, the carb is for a 1963-65 passenger and Corvette 250 HP.
