Where can I purchase new C1 283 motor assembly bolts/washers or kit? - NCRS Discussion Boards
  • Mark S.
    • January 26, 2013
    • 88
    Where can I purchase new motor assembly bolts/washers, preferably a kit, which will pass NCRS judging? I am assembling a 1960 270hp motor and seeking sources for the following:
    Cylinder Heads
    Aluminum Intake Manifold
    Exhaust Manifold
    Oil Pan
    Timing Chain Cover
    Water Pump
    Fuel Pump
    Pulleys
    Fan
    Fan Clutch
    Starter
    Bell Housing
    Many thanks in advance.
  • Thomas H.
    • August 31, 2005
    • 1061
    Re: Where can I purchase new C1 283 motor assembly bolts/washers or kit?
    Check with Richard Fortier. He advertises in Driveline
    Tom
    2007 Z06, Lemans Blue
    • Bruce B.
      • May 31, 1996
      • 2930
      Check with Totally Stainless, they have complete engine bolt kits.
      • Dick W.
        • 10483
        Agree with Thomas, Richard Fortier is the man
        Dick Whittington
        • Donald H.
          • November 2, 2009
          • 2586
          I used bolts from Paragon, Corvette Central, etc. to assembly my 1960 245HP engine. The only deduct I got related to engine bolts at the Bowling Green Regional was for the bolt that holds the road draft tube in the back of the engine. Of course, what I used were reproduction bolts, so if you are looking for 'originals' Richard Fortier is your best bet.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
