1967 Kick Panel Carpeting Backing - NCRS Discussion Boards
  • Tom R.
    • December 20, 2010
    • 177
    When I received my carpet kit, the carpeting for the kick panels did not come with any kind of stiff backing to keep them straight and smooth when screwed down to the kick space area. What is the opinion on what we should use? This is a complete carpet set ordered from Willcox for a coupe.
    Thanks.
    Tom
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11322
    Re: 1967 Kick Panel Carpeting Backing
    Tom, The panels are made of thick paperboard. Most vendors only sell them with the windlace and carpet already attached.
    Just checked. LI Corvette has them bare with windlace. You need to specify color of the windlace......12-42B
    You may also need the metal trims...12-37B
    It sounds like you didn't know that you needed them at time of the Wilcox order. They could have got you set up with the carpeted panels, if they knew you didn't have them. Maybe check back with them as they may do a swap out for you with a extra cost.
    Rich
    • Tom R.
      • December 20, 2010
      • 177
      Thanks Rich. I knew there was something, just surprised that when you order a complete carpet set with jute and rubber backing, you'd think the supplier wouldn't make you specify a needed part like cardboard backing.
      Tom
      • Gerard F.
        • June 30, 2004
        • 3805
        Tom,
        I ran into the same problem. Even with the complete kick panels with backing and windlace, I don't think anyone reproduces the 67 kick panels like the originals. Here are photos of my original 67 kick panels:
        Driver side front:
        Driver side back:
        I think you will find the complete repro with backing will have a plastic backing and will be missing the lower center eyelet.
        The repros have different eyelets which on the originals went through both the backing and carpet. You just can't find those eyelets anymore.
        But all is not lost, most judges only look at the screws from the outside. As long as the screws (6 alike on some, and 4 & 2 alike on others) are correct, you'll get by.
        I'm thinking about just re-dyeing my originals and putting them back on with the repro carpet set.
        Jerry Fuccillo
        • Tom R.
          • December 20, 2010
          • 177
          Thanks Jerry,
          i found a vendor that has both the eyelets and wind lace in the correct color along with a plastic backing that would mimic the Fiberglas backing you show on your originals. I'll give them a call this week. Thanks again.
          • Gene M.
            • April 1, 1985
            • 4232
            Tom,
            My carpet for the sides did not come installed to anything as the originals were.
            I use a thin sheet of 1/32" ABS plastic as a backing. It is very flexible and easy to work with. I got it at arts and crafts store. Cut it to shape with scissors. Then just drill holes using the original backer as a pattern for the rivets.
            I just do not like the idea of cardboard as original, after all once installed there is no appearance differences.
            • Tom R.
              • December 20, 2010
              • 177
              Originally posted by Gene Manno (8571)
              Tom,
              Wow Gene. I hadn't thought of that. I was always thinking thick poster board and not that thin ABS. I have some old wind lace in Dark Saddle and could remove it from the old carpet pieces then mate them up on the ABS. No real additional cost!! Thank you sir.
              Tom
