TCS hoses
Re: TCS hoses
Mike,
by entering
transmission and control and spark and solenoid in the search box
I received a full page of threads that might show the info you need.
see the page of responses here --->
https://www.forums.ncrs.org/search.php?searchid=144844- Top
Re: TCS hoses
Short answer - it makes no difference from a technical point of view. The ports are both open or closed at the same time depending on the solenoid. It's not an "either-or" scenario.
Having said that the routing in the upper photo is what I would expect. It's neater and has less chance of interfering with the air cleaner.Vice-Chairman (West), Michigan Chapter NCRS
Re: TCS hoses
Mike, Rather than rely on photographs which as you have found are only confusing, why not use the AIM? That is the instructions to the employees installing the parts and not someone's idea that may or may not be accurate.Terry- Top
Re: TCS hoses
that first pic is one I posted awhile back. John Hinckly gave me a great explanation as to how those ports operate. I'll see if I can find it. I believe it does matter as to how the hoses connect. You could try each way while you shift into third and check the rpm rise.
tcs.jpg- Top
