Whats a good resource for correct part numbers for a 68 Engine? - NCRS Discussion Boards
  • Steve W.
    • March 1, 2002
    • 78
    Looking for the correct GM parts (and numbers) for the Valve components for a 68 L89 Engine. What's the best resource? (the Assembly Manual doesn't list these part numbers). Thanks, Steve
  • Dick W.
    • 10483
    Re: Whats a good resource for correct part numbers for a 68 Engine?
    I seriously doubt that any of the parts are available from GM today. Aftermarket has many suppliers of valve components. VS 1581 Sealed Power is the spring, Clevite 2165145 is the # for keepers, 2164103 is the Clevite # for retainer, Sealed Power 1905 for intake valves, and VS 1861 for exhaust valves.
    You have to realize that GM did not make valves, pistons, rings, springs, etc, they were all sourced from Federal Mogul, TRW, etc back in the day. They probably make fewer parts in house today.
    Dick Whittington
    • Patrick B.
      • August 31, 1985
      • 2012
      Dick, a 68 L-89 uses 1.84" (not 1.72 or 1.88) exhaust valves. Does any company make or stock them? I haven't been able to find a source.
      • Steve W.
        • March 1, 2002
        • 78
        knowing the GM part numbers would be helpful because there are still NOS parts floating around (which I would prefer to use when possible). Yes, Clevite, TRW etc when NOS can't be found. thanks, Steve
        • Mark H.
          • December 27, 2007
          • 135
          Takes a while to download (101Mb) but worth it. Here is a free, complete 1953-82 GM Corvette Parts and Illustration Catalog with everything you are asking for. Mark http://www.wedophones.com/Manuals/Ch...es 104 Meg.pdf
          • Michael H.
            • January 29, 2008
            • 7477
            Steve,
            If I remember correctly, everything would be the same as a 435 HP with cast iron heads with the exception of the exhaust valves. I don't remember the head diameter but I think I still have some here and if I can find them, I'll measure the head diameter.
              • 43279
              Steve------
              The following represents the last available GM parts for the application and not necessarily the original part numbers:
              VALVE, intake------------------GM #3864808-----discontinued
              VALVE, exhaust-----------------GM #3879619-----discontinued
              SPRING, valve-------------------GM #3970627-----discontinued
              CAP, valve spring----------------GM #3859909-----discontinued (GM #3964264 will also work)
              KEY, valve spring-----------------GM #3947880-----available
              ARM, rocker----------------------GM #6258611-----discontinued (GM #3959182 will work and remains available)
              ROD, valve push, intake-----------GM #3946067-----discontinued
              ROD, valve push, exhaust---------GM #3946069------discontinued
              GUIDE, pushrod-------------------GM #3860038------available
              LIFTER---------------------------GM #5232720-------discontinued
              • Dick W.
                • 10483
                Patrick if that is the case, I would open the seats up to use the 1.880 valve. Not a big deal, just a couple hours of machine work. Or machine the 1.880 valves down
                Dick Whittington
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Patrick,
                  You are correct. 67 through 1st design 69 aluminum heads use 1.84 exhaust valves.
                  • Joe R.
                    • July 31, 1976
                    • 4552
                    Steve,
                    You don't need to look or find ANY NOS GM parts as the valve train for the L-89 engine was trash in 68 and just older trash now. The 3X2 engines dropped valves faster than Chevrolet could warranty them. That is why there are no real 435HP or L89's out there that are real. That is valve train real.
                    Find you a good source or engine rebuilder to make recommendations for your L-89.
                    All of the components are available thru the aftermarket such as Dick, Joe and Patrick have mentioned. AND the available valve train parts are much improved over the 60's stuff that GM sold over the counter.
                    JR
                    • Steve W.
                      • March 1, 2002
                      • 78
                      thanks for all the replies, Best Regards, Steve
                      • Steve W.
                        • March 1, 2002
                        • 78
                        the lifter 5232720 is a hydraulic lifter, I'm pretty sure the L89 uses Solid Lifters?
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Joe,
                          What you say is true, but GM solved the problem with the 3970627 valve springs in maybe 69 or 70. My 66 L72 had problems with broken springs, but was promptly fixed and never dropped a valve.
                          Joe
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Originally posted by Joe Raine (45823)
                            Joe,
                            Joe
                            I agree. I replaced all of the original springs in my 425 HP car almost 30 years ago with the 3970627's and have had zero problems.
                            • Dick W.
                              • 10483
                              Sealed Power AT 992 is mechanical
                              Dick Whittington
