Vacuum advance solenoid 72 LT-1 - NCRS Discussion Boards
  • Les W.
    • July 31, 1990
    • 54
    I am looking for NOS vacuum advance solenoid for my 72 LT-1 with a/c. Is there a part # and what year corvettes used the same #? Going to Bloomington to look for one, any help would be appreciated.
    • 43259
    Re: Vacuum advance solenoid 72 LT-1
    Les-----
    The part number is GM #1114451. It was discontinued without supercession in July, 1989. As far as Corvettes go, this piece was uniquely applicable to 1972.
    • Les W.
      • July 31, 1990
      • 54
      Joe, thank you for the info. I looks as though my findings are limited. Is there a way to find the # on the solenoid?
        • 43259
        Les-----
        Yes, the part number is usually found embossed on the plastic end of the solenoid or embossed or printed in the steel frame of the solenoid.
        • Les W.
          • July 31, 1990
          • 54
          Les-----
          Joe, thanks I hope I can find one.
          • Les W.
            • July 31, 1990
            • 54
              • 43259
              Les-----
              You should not have any trouble finding one, but NOS will be more difficult. I believe that original examples had the part number embossed on the plastic end. Those with the part number on the metal frame ("barrel") I believe may be later SERVICE pieces.
              I feel pretty confident that a lot of these things got removed early-on by owners and immediately junked. I'll bet there are untold numbers rotting away in landfills.
              • Sal C.
                • December 1, 1984
                • 430
                Part number will be stamped into the mounting bracket.
                  • 11679
                  Easy to find on eBay. The odds of finding one at Bloomington are small.
                    • 43259
                    Sal-----
                    I always thought the part number was stamped into the plastic on the end of the solenoid. However, as I look at the examples on eBay it appears that what I thought was plastic is actually metal and part of the bracket. I've got to admit, though, that I've never really taken much interest in these things so I probably didn't look close enough or with much care.
                    • Paul O.
                      • August 31, 1990
                      • 1716
                        • 11679
                        And, the backside of the bracket usually has a different part number for a different solenoid.
                        Not visible unless you remove the bracket, of course.
                        • Les W.
                          • July 31, 1990
                          • 54
                          Thanks for your help!
