1957 corvette wiring - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    I am in the process of completing a frame up restoration. As part of this project, I decided to rewire because the original wire was becoming to brittle. Now the car will not start that is there is spark. I have doubled checked all wiring circuits and guages. I do have one question. What is the correct position of the pink and red on the circuit borad. One thing that really is prizing me is the resisiter is always powered up with 12 volts. Thanks for any help.
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 1957 corvette wiring
    Jerry; need more info; What circuit board are you talking about? Do you have juice to the coil? A bad condenser in the distributor will cause no spark. Are you getting spark to the points? To trouble shoot wiring you start at the source (battery) and work your way forward. Just my old 2 cents
    • Garry B.
      • January 1, 1991
      • 660
      Jerry, I have a picture of the fuse panel that I think you are looking for. Unfortunately, I can't seem to load it on tiny pics. Send me a private email and I will send it to you that way if you want.
      Garry Barnes #18531
      Garry Barnes #18531
      '67 Lynndale Blue Coupe- National TF, BG
      ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
