NO SPARK...please help - NCRS Discussion Boards
  • Ronald F.
    • September 29, 2012
    • 135
    Yesterday, my '67 L71 ran beautifully. Had so much fun driving it. This am, it turned over fine, but no start. Was able to smell gas. Pulled a spark plug to see if it was fouled, looked fine. Checked for a spark and found NO SPARK! It has the original, rebuilt TI distributor. What could it be? I hope it's a simple fix. I'm not too mechanically inclined (yet). But if it's simple and someone could walk me thru it, I'll give it a try. THANKS!!!
  • Bob H.
    • July 31, 2000
    • 801
    Re: NO SPARK...please help
    Hi Ronarld
    Check out Fiedler's website for troubleshooting help
    I believe this will help you find the problem as it could be anywhere in the TI system.
    • Carl N.
      • April 30, 1984
      • 592
      First check and make sure your TI module is grounded, then check and be sure the connection from distributor to TI wiring is secure, if you have an original TI wiring harness (runs from dist to module) it may be time for a replacement as the wires may be brittle. Let it sit over night and allow the TI module to cool off - if it starts and runs then the module is failing. If the module is original it may have problems and require replacement - if this is the case I would suggest R&R with a new TI board from Paragon or another vendor rather than a NOS module - these are very simple to swap out --- other than the TI side check rotor and cap and be sure proper contact is being made - you may also want to search this forum and the "other" forum for solutions.
      • George W.
        • July 31, 1998
        • 322
        Sounds like an electrical matter, I would start by checking to insure at wires at tight; at coil, starter, dist., etc; then connect a tester, ground the end to anything and stick the point to elect connections to insure power is flowing.This is sorta the standard place to start with electrical problems; it will tell you if elect power is flowing to start car; good luck.
        Dr. George
        • Dick W.
          • 10483
          Good site with a lot of information about troubleshooting http://bit.ly/11UzbvE
          Dave is the go to source for parts and repairs.
          Dick Whittington
          • Doug M.
            • January 1, 1991
            • 68
            Ron, Unplug engine compartment wiring harness at firewall, clean contacts, then make sure the connection is firmly attached.
            • Ronald F.
              • 135
              Doug, just to make sure I get this right, is this under the dash on the inside of the car, driver's side. Or is it under the hood? Any chance you could upload a pic? This is unfamiliar territory for me. Thanks!
              • Dave S.
                • August 31, 1992
                • 2924
                Ronald,
                If all the wiring connections are OK then the culprit may be the Pole piece in the distributor. Often times they cause the symptom you have but the car will run fine the next day.
                Good luck w/ it. Dave Fiedler is the guy.
                • Doug M.
                  • January 1, 1991
                  • 68
                  Ron, It is on the engine compartment side, under the hood, plugs into the firewall beside where the clutch rod has entered the engine compartment. If you have a power brake booster, may be hard to see.
                  • Ronald F.
                    • 135
                    Just for closure, it turned out to be a loose connection at the TI amp connector. A little wiggle and snugging and she fired right up. Thanks to all for the help!!
                    • Mike E.
                      • February 28, 1975
                      • 5137
                      Thanks for closing the loop. It's thoughtful to let others know they were helpful!
