Very early 1967 AC 40482 Fuel Pump - NCRS Discussion Boards
  • Michael S.
    • April 1, 1990
    • 68
    Has anyone else seen an AC 40482 that has the same bottom square fittings as an AC 40366? When I first asked about the correct fuel pump that should be on my car I got a response from a fellow NCRS memeber that sent or attached photos of his original AC 40482 pump. The photos of his August AC 40482 fuel pump removed from his very early '67 had the exact same bottom fittings as a late AC 40366. The pump had an August 66 date and 40482 stamped on it. Again, the fittings were exactly like the fittings on a late AC 40366 pump.
    Does anyone know when the "bent tube" configuration first appeared on the bottom of the AC 40482?
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Very early 1967 AC 40482 Fuel Pump
    There is a guy in California that has the prints to tell you.
    • Michael S.
      • April 1, 1990
      • 68
      Do you know how to contact him?
