65 cam removal - NCRS Discussion Boards
65 cam removal
  • William P.
    • August 31, 2003
    • 135
    65 cam removal
    Hi, Will the cam slide out of a 65 small block without removing the rad saddle ?
    Regards Bill
  • Tim S.
    • May 31, 1990
    • 715
    Re: 65 cam removal
    Yes it will. Just unbolt your trans mount and use a floor jack to change the angle. Just did mine over the winter.
    • William P.
      • August 31, 2003
      • 135
      Re: 65 cam removal
      Thanks , Bill
        Re: 65 cam removal
        Regards Bill
        Don't forget to remove the fuel pump and actuating rod.
