I was out for a morning cruise in my 67, when what to my wondering eyes should appear--the temperature gauge was pegged all the way to the right. Pulled over, popped the hood and all three belts were off (mine's a power steering, AC, 327/300). Call tow truck and get the car home and head off to the auto parts store for new belts.
My questions--I've been under the hood of this car a lot lately and just finished all my maintenance including checking the belt tension--using the rule of thumb to check for 1/2" deflection--and everything looked good to me. And none of the three belts broke, however the alternator-water pump-crankshaft belt had a nick in it and was twisted around pretty good. Could that have been the start of a break and enough to knock all the belts off?
And it's been a really long time since I've touched belts on any car I've owned--is there something I should inspect/look at aside from the obvious--pulley alignment, anything visibly wrong with the pulley surfaces, ect??
Also, since the AC does not work (hasn't blown cold air for the entire 3 years I've owned the car, is there any downside to not hooking up the AC compressor belt?
Can someone confirm the length for the alternator-water pump-crankshaft belt--NAPA who has guys behind the counter that know something, were out of that belt, and O'Reilly's showed the belt I bought as being for a 327/350 hp excluding power steering, as opposed to my 327/300 hp with power steering and AC. It's Gates XL 7570 13/32" X 57 5/8". Is that the correct belt?
Finally, the power steering pump belt looks like that's going to be a two man operation--any tips on getting that belt tensioned without drafting a helper.
