According to the 69 TIM & JG there should be an "additional black plastic insulator" as part of the 69 Antenna assembly. The 69 AIM (U69/B1-attached) shows this insulator as a 'gasket', GM # 3138635 (Item 15). I've contacted a few vendors and no one has ever seen this insulator ('gasket') installed on a car. Can anyone provide me with any additional info concerning this 'gasket'? Dimensions, photo, where to purchase one, point deduction for not having one installed? Thanks Wes69 Antenna.jpg
69 Antenna Gasket
Re: 69 Antenna Gasket
Wes, that same o-ring (gasket) was used on the 67-69 Camaro, 67-69 Firebird, 65-69 Corvair (and others I'm sure). In reality, it started life as an evaporator seal for 57-58 full size cars with A/C! The inner diameter is .739 and you can probably find it just about anywhere that sells o-rings, but if you can't find it, you can get it at Heartbeat City. HERE'S the direct link.
Ed- Top
Ed, I went out and bought two O-rings. The smaller O-ring (# 210) measures approx. .739" ID with a thickness of approx. .14". I've attached a picture of what it looks like sitting on the bezel. Is that what it's suppose to look like? I bought a bigger O-ring (# 213) for comparison which measures approx. .960" ID with a thickness of approx. .14" which pretty much covers the entire flat surface of bezel. Thanks Wes Large O Ring.jpgSmall O Ring.jpg- Top
