Info needed on disassembling a '64 clock housing - NCRS Discussion Boards
  • Jeff H.
    • September 30, 1988
    • 53
    Does anyone have any tips or suggestions on how best to disassemble the plastic bezel & lense from the clock assembly? I'm intending to repaint the bezel, polish the plastic lense & clean the clock face. The clock itself works fine, but it's not obvious as to how the bezel is attached to the stamped metal clock housing. Has anyone out there gone thru this process? Thanks for your help.
  • Alan D.
    • January 1, 2005
    • 2038
    Re: Info needed on disassembling a '64 clock housing
    I'll assume you have it all apart except the stem. Was told by the clock re-builder the stem just pulls off. I held and pulled and pulled to the point where I felt it would brake. So sent to re-builder. Looks like he even had a hard time since stem now has deep marks on it.
    Good luck, hope yours comes apart.
    • Paul J.
      • September 9, 2008
      • 2091
      There's a little bit of information in here:
      https://www.forums.ncrs.org/showthre...=clock+rebuild
      • Jeff H.
        • 53
        Thanks for your help on how best to disassemble a C2 clock. I appreciate it!
