427 oil pressure fitting - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2015
    Which of the fittings in the photos is the right fitting to plumb the oil pressure line to the block of a 427? Is the other fitting the right one for 70 LT-1?
  • John C.
    • January 1, 2005
    • 616
    Re: 427 oil pressure fitting
    Patrick
    The straight fitting on the left is the correct one for a solid lifter BB in 1967.
    The 45 degree angled fitting on the right looks to be from a 1968+ BB engine.
    John
      • 15637
      I am pretty sure nothing you have there is for a 1970 LT1. I think all small blocks need no adapter. The hole in a small block is 1/8-inch pipe thread.
      Edit add: Pat if you want a photo of the 1970 LT1 fitting, let me4 know and I'll take one for you. I don't thinkl I will have to do much dissassembly to get to it.
      • Patrick B.
        • August 31, 1985
        • 2015
        Thanks guys. I glad to learn there was a difference in fittings between 67 and 68.
        • Kim C.
          the 45 degree is for 67 427 auto
          • Patrick B.
            • August 31, 1985
            • 2015
            Thanks Terry, but I hadn't looked the 350 block for a while and just assumed that what wasn't for a BB in my pile of stuff was for a small block. A problem of having too many things apart at the same time. Thanks for reminding me that the SB has a 1/8" pipe thread in the block. I know what it needs from that info.
            Also, the comment that a PG 427 uses the 45 degree fitting is interesting, but mine is L-71 4 speed so I will use the straight fitting. Thanks all for the info.
