Carter AFB jet size - NCRS Discussion Boards
Carter AFB jet size
  • Jim C.
    • May 31, 2000
    • 96
    Carter AFB jet size
    Can someone tell me what the correct jet and metering rod sizes are for a Carter 3406S or 3461S? 1963 340shp
    Jim Cear
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Carter AFB jet size
    Jim,
    Primary jets .104, primary metering rods 16-389 (.060-.069), secondary jets .0689.
    • Stuart F.
      • August 31, 1996
      • 4676
      Correct yes, but good luck trying to find any after market jets that measure up correctly.
      I trust Jim meant 3460S and 3461S.
      Stu Fox
      • Terry D.
        • May 31, 1987
        • 2698
        Jim, try www.carburetor-parts.com he has some jets listed and may have others.
        • Jim C.
          • May 31, 2000
          • 96
          I found the .104 main jets in an Edelbrock strip kit I had . In looking at their AFB knockoff carbs they use about a .95 jet in secondaries for their street/performance carbs. I think I'll give those a try just to see how it runs. I also several rod pairs in the kit I may try.
          This all started when I took the top off my carb and found someone put a secondary jet in one of the primaries and to make matters worse the metering rod was stuck in the jet! GRRRRRR
          Jim Cear
          • Stuart F.
            • August 31, 1996
            • 4676
            Terry;
            FWIW, The company you referred to is also known as "Carburetors Unlimited" is where I too bought many AFB parts, and is the source where I got the jets that didn't measure up correctly.
            There are a lot of subtle differences between Carter AFB's and Edelbrock parts.
            Stu Fox
