54 windshield sealing - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Two questions........Getting ready to set the windshield, the original looks like it had some dum-dum in there. What do you folke use to seal the windshield to the body channel? Also, Should I lubricate the Tach cable?
    Thanks again, Guy
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 54 windshield sealing
    Guy
    center the seal on the windshield and tape it to the glass - about every 12" or so
    as you assemble the windshield the seal will want to come off the glass
    once you build the frame and install it you can use a razor blade and trim the tape....
    You can use some dum dum around the holes in the body to prevent leaks....but they all leak....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Chris, great info!!
      • Troy P.
        • February 1, 1989
        • 1284
        You should lube the cable with cable lube available from GM. Don't use regular grease as it hardens with age and can melt at temperature and climb the cable into the cockpit.
