Redline - NCRS Discussion Boards
Redline
  • Jim C.
    • May 31, 2000
    • 96
    Redline
    How often , if at all, do you run your up close to redline?
    Jim Cear
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Redline
    In the 60's, I did it a LOT.
    In the 70's, less.
    Now, in the 21st century, I see no point. Sooner or later, something expensive/critical is going to fizzle.
    (assuming we're talking about old C1's and C2's)
    • Mike F.
      • April 25, 2011
      • 668
      Re: Redline
      I run to redline as often as I can (70 L46). That's what it was designed for.
        • 15632
        Re: Redline
        I am with Mike Hanson. But was it four years ago when my 2008 was new and the Michigan Regional got to tour Milford? A whole lot that day, of course the car was new and I would not have been ashamed to tell the Chevrolet engineers I know that I broke it at Milford, and ask them to fix it on the warranty.
        BTW: I won't tell you who it was but on the 2.9 mile straight my passenger yelled at me (he had to because the exhaust was open over 3K rpm) to slow down before they throw us out. I think he will remember to his dying day the big grin he got in response.
        If that car isn't illegal anyplace in this country at redline in first gear, I am sure it is in second gear.
        • William F.
          • June 9, 2009
          • 1364
          Re: Redline
          Right on Mike. If you don't (or car can't) pull to redline ,at least occasionally, may as well drive a "PIOUS."'67 L79, '67 L36, '62 340 hp
          • John S.
            • May 4, 2008
            • 427
            Re: Redline
            Not so ashamed to admit taking my 35k mile 65 fuelie to redline more then once in the last week or two. May have to work that out of my system or maybe not!
            I will tell you the car pulls to 6500 rpm with no problem and would probably go past it.
            John Seeley
            67 Black/Teal
            300 hp 3 speed coupe
            65 Maroon/Black
            35k mile Fuelie coupe
            • Michael H.
              • January 29, 2008
              • 7477
              Re: Redline
              Mike,
              Running to redline in a 70 hydraulic lifter L46 is a whole different deal than running to redline in a solid lifter engine that will easily go to 7000 RPM. I think you're all done at around 5500 RPM with your hyd lifter L48?
              7000 RPM on those 50 year old connecting rods, bolts, bearings and valve springs on a solid lifter 50's or 60's engine is a different issue. That's just asking for trouble. And when some rotating component is sticking out the side of the block with anti freeze dripping off of it, there goes the original block. (although, I hear replacement original blocks aren't all that difficult to find these days)
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: Redline
                I try to limit my L-76 63 to 5500 rpm, but it is ohhh so hard to do when it wants so bad to go higher. Perhaps I need to get one of those ignitions with an adjustible rev limiter, cause I just can't discipline myself - nor can my engine. With the 3.36 final, second gear does put me illegal so that's a little easier to limit.
                Stu Fox
                • Jim C.
                  • May 31, 2000
                  • 96
                  Re: Redline
                  my 63 340shp makes one hell of a noise above 4500 . Those solid lifters sound like they are ready to shoot right through the heads . I have an 097 cam as well
                  Jim Cear
                  • Carl N.
                    • April 30, 1984
                    • 592
                    Re: Redline
                    L78 is redlined at 6500 sooo 'bout once a week weather permitting I'll pull around 6,200 thru 1st and 2nd, but unlike Terry I can still stay close to local 70 mph speed limit in Texas in 2nd --Wife's C5 is whole other story so I'd have to guess it hardly ever if ever sees redline (couldn't even tell you what redline is without going in shed and looking),
                    • Michael J.
                      • January 27, 2009
                      • 7167
                      Re: Redline
                      I do take my '67 L71 to near redline (within 400 rpm) most every time I have it out, that is what it was made to do, as Mike says. I do it in first gear, so as to not exceed the speed limit by too much. Now, in my 2012 ZR1, I do it regularly too, but in several of the other gears I have.
                      • Jim L.
                        • September 30, 1979
                        • 1817
                        Re: Redline
                        The car in my avatar? Anytime. Anywhere. My unrestored '54? Never. 3500 RPM tops.
