Brake pedal too firm after new Master Cylinder installation - NCRS Discussion Boards
    • 11643
    A couple of weeks ago I was taking the orange 72 for a ride and in the last mile or so the pedal started to go to the floor as I sat at stop signs. Given that the only part not replaced a few years ago was the aftermarket master cylinder I knew where the problem was (car had sat 15 years previously). After talking to the car's owner we decided to purchase and install the new "correct" reproduction. The car has power brakes, and the original booster is still in place.
    I order the repro and installed in on Wednesday after bench bleeding it. The entire system was then bled. No issues, and because it was raining I did not test drive the car. Yesterday the owner came over and was ready to pick it up, but we found that on driving it the pedal was really, really firm, had little play before stopping, and the car stopped slower than expected. We test drove it around town, no improvements noted, so over a few hours last night we bled it 3 times with no change in pedal feel or road function. I checked the depth of the pushrod hole and it matched the previous MC, we checked the pushord and we checked how it all seated together. No issues were found. All 4 calipers are working and the wheels turn freely when brakes are not applied.
    As it sits, every time you press on the brakes you have to push quite hard, and it really is like pushing on a brick. This is vastly different than the cars has ever been before. It is like all of the "feel" is gone from the brakes, and it is more like pushing on a non-power brake pedal than a power brake pedal. The other two PB Corvettes here feel nothing like this as well. If you stomp on the pedal as hard as you can it will not lock the tires or even get close. You will stop, but not quickly.
    Given that the only part that was changed is the master cylinder my assumption (!) is that the new master cylinder has a problem. Would you agree? I plan on calling the vendor on Monday to see about getting a different one if consensus is that the MC is at fault.
    Patrick
  • Jimmy B.
    • July 31, 1980
    • 584
    Re: Brake pedal too firm after new Master Cylinder installation
    check vacuum source to the pb booster. Good luck!
      • 11643
      Still looks good, didn't change that at all. Even checked a bit inside when I removed the MC, and no issues visible.
      I can't think of any reason it would have changed.
      • Paul O.
        • August 31, 1990
        • 1716
        Patrick
        The problems is different then when you started so would agree M/C problem. But many years ago had a 1973 P/B car replaced M/C and had a very stiff pedal and after a period of driving the brakes would lock up found the P/B rod in the booster as the problem had to readjust the length cured problem.
        Just thought of this check with the engine off depress the brake pedal several times till you have full resistance then start the engine pedal should move down and have a softer feel. If it does not bad booster or vacuum problems.
        • Brian M.
          • February 1, 1997
          • 1839
          Try disconnecting the Vac line to Powerbooster and reconnecting.
            • 11643
            Patrick
            Paul,
            I'll give that a try, possibly tomorrow.
            I checked it out this evening briefly as I had to move the car. Compared to every other PB car I own the pedal just doesn't seem to go very far before it's hard as a rock.
              • 11643
              I had to remove it to power bleed it, so this has been done. I didn't see anything wrong with the vacuum line, though I will check it out further.
                • 15601
                I chased this kind of issue on a friend's 1969 many years ago. Car had manual brakes. In the end we found he had a PB master cylinder installed by Bubba years before. Check diameter of MC -- I am pretty sure that can be done from the rear, but if it has the right casting # for PB only a machining foul up would cause this. BTW: The 1970 TIM&JG has the wrong PB MC casting #. The new 1968-69 has it right.
                • Dick W.
                  • 10483
                  Paul,
                  You should have free play in the rod from the pedal, would not be the first time I have seen the issue. Do the brakes build up after you drive it for a while?
                  Dick Whittington
                    • 11643
                    No, they are hard from the moment the car starts.
                    You can push the pedal down somewhat, but it feels like it's about half of normal before you hit a brick wall with your foot.
                    • Dick W.
                      • 10483
                      Reach up under the dash and take hold of the push rod. It should have some free movement in it. If not you have found your problem. Several years ago a customer brought me a car that he had taken to three or four other shops. He would drive it a few miles and then the brakes started getting hot. I had sold him a set of calipers several months before and he finally decided that all four calipers were bad and causing this. Started checking and found the push rod was tight. He finally admitted he had gone to AutoZone and purchase a M/C because the one we sold was too expensive. Needless to say he paid dearly for the money he saved on the M/C.
                      Dick Whittington
                        • 11643
                        OK, I know what you're describing. I had a problem with my 70 Cutlass that was similar.
                        However, the pushrod in this car did not change, and the bore depth of the new MC mics out the same as the one I removed. So, the odds are low.
                        I checked the depth because I too wondered about a similar situation.
                        • Bob J.
                          • December 1, 1977
                          • 714
                          Patrick
                          I think this test would be the first one I would do. Bob
                            • 11643
                            Patrick
                            Ding Ding! We have a winner.
                            I tried the test a couple of times. Pedal doesn't change when the car is started.
                            I then checked the vacuum line, and the engine is giving plenty of vacuum to the booster. Check valve is working.
                            Turned off car and I now hear a leaking vacuum hiss at the power brake booster - a noise that wasn't previously there.
                            Anyone know of a good brake booster rebuilder with quick turnaround?
                            • Dick W.
                              • 10483
                              Booster Dewey
                              Dick Whittington
