65' Battery Change procedure - NCRS Discussion Boards
+ More Options
Posts
  • David K.
    • September 30, 1992
    • 281
    Hello; I have a modern day battery in my 65' 327/365hp car. I would like to change the battery myself for a reproduction 'Delco' Tar Top. The working area looks very tight with the rad expansion tank on top of the battery compartment. Can I get the battery out for the swap, without removing any parts (expansion tank etc..) ? If someone could walk me through it - would be much appreciated ! Thank you; David
  • Hank D.
    • January 1, 1999
    • 137
    Re: 65' Battery Change procedure
    The information in the post at the following link should help:
    https://www.forums.ncrs.org/showthre...expansion+tank
