Part I.D. question, is this a corvette part - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 944
    This in new still in the box, Before I throw this out, I would like to know what I bought it for?, GM Part #352133 gr 0.724.
    Do not think it's corvette, had a chevy vega once, may be a timing belt
  • Carl N.
    • April 30, 1984
    • 592
    Re: Part I.D. question, is this a corvette part
    per GM Chassis & Body Parts Catalog for Corvette 1953 thru 1976 effective June 1976 Group 0.724 was for Chain, Camshaft Timing - p/n' s 3704150, 3860036, 346261 (yes just 6 digits not 7 as expected) and 3902428. April 1977 GM Chassis Parts Catalog gr. 0.724 shows Timing Belt 75 All 122 352133 1 13 20 timing 75 All 122 334051 1 5 30 distributor drive 1 056 75 All 122 334098 2 35 BOLT timing -- so -- I would guess Vega may be correct others with more knowledge of Vega may chime in
    • Edward B.
      • March 29, 2013
      • 691
      Yes, a timing belt from a 122CI four cylinder.
      As Carl and I both did, HERE'S a great place to look up part numbers.
      Ed
        Carl -
        The 122 (cu.in.) Vega application was the Cosworth-Vega, not the regular Vega - the regular Vega was 140 cu. in.
        • William B.
          • April 30, 1975
          • 944
          thank you everyone, guess I'll find a friend that has a Vega
            Bill -
            It'll only work on a Cosworth-Vega, and not many were built (DOHC, fuel injection, 16 valves, etc.) - Duke Williams has one.
