Radiator/Coolant question - NCRS Discussion Boards
  • Jeffrey D.
    • April 1, 1989
    • 27
    I've begun the process to replace my suspected faulty heater core, the problem for which I
    posted about a week ago.
    So the first step was to drain the radiator. I opened the pet cock (why on earth do they call
    it that?!?) and NOTHING drained out! I opened the overfill tank and there was just a small amount
    of coolant in the neck of the tank.
    When I first noticed there was a problem with the car, it was due to coolant dripping into the passenger
    floor, approx 2 pints worth.
    Can anyone suggest WHY I can't seem to drain the radiator ? I would think it's highly unlikely the system
    is dry as I've during recent idling driving never had the temp gauge go past normal.
    Jeff
  • Al R.
    • June 30, 1988
    • 688
    Re: Radiator/Coolant question
    The petcock is probably stopped up with crud. Try using a stiff piece of wire or paper clip to run up into the hole of the pet cock to start the coolant flowing.
    • Jeffrey D.
      • April 1, 1989
      • 27
      Well look at that! I never thought it could have been stopped up with stuff, but in fact it was!
      Al, thanks for the heads-up, I appreciate it.
      The radiator is now drained and I've removed the faulty heater core.
      Jeff
        • 15631
        I wish I had suggested this before you had the new heater core in. Flush the system. Radiator & block thoroughly. Put a adapter connector (suggested in your other post, I think) on the heater hoses to by-pass the new heater core. You don't want crud from the block & radiator to get in your new heater core. With the pet cock (I too wonder where that name came from) blocked with crud it sounds like you have a serious cleanliness problem. Get rid of that crud or your radiator will be next.
        • Jim T.
          • March 1, 1993
          • 5351
          Jeff
          If you have never removed the block drains when changing the coolant, you could get a lot of "stuff" as well from the block.
          • Anthony S.
            • September 3, 2007
            • 108
            "pet cock (I too wonder where that name came from)"
            cock -
            A faucet or valve by which the flow of a liquid or gas can be regulated. Middle English cok, from Old English cocc, probably from Late Latin coccus, from coco, a cackling, of imitative origin.
            Petcock -
            A small valve or faucet used to drain or reduce pressure - from pet1 or perhaps French pet, from 1
            There are two kinds of friends; the friend you call to bail you out of jail and the friend sitting next to you in the cell saying "Damn, that was great"!!!
              • 15631
              cock -
              Petcock -
              Thanks for the research.
              • Stuart F.
                • August 31, 1996
                • 4676
                I have never been able to just open the petcock and get coolant to drain because I have yet to have one work as it is supposed to. The handle usually spins loose from the valve and I end up having to remove the entire valve from the radiator fitting. I got tired of changing the valves many years ago and just remove the valves now. It is just as easy to use a hex wrench as wrecking the valve handle with a plyers.
                Stu Fox
                  • 15631
                  Stu Fox
                  I am not sure about C2s, but C3s never came with a petcock. A hex head plug of the appropriate material was the factory installed drain fitting.
