Re: 72 wiper door
Keith,
The fact that removing the wiper fuse from the fuse box does nothing, says a lot.
First, like you said, check every fuse, but also check any wires that are plugged into the box too.
Then I would go back out to the engine side and unplug every plug to see what changes. If you unplug the wires to the switch we were talking about that is on the firewall. Check everything you can find.
If you can, take a high resolution picture of you wiring harness. Send it directly to me. That way it is not too big for the site.
Where are you located?
Do you have a good wiring diagram? If not I can send you one.
Now, it is figuring out where the splice is. We will, just like we got the headlights.
We will do the wiper vacuum as soon as we are done with this. That is pretty simple.
Maybe Terry can chime in about the difference in early 72 wiper motors (Aug 71) and later ones like mine (April 72).
Monte
Keith,
Monte
