83 L84 Distributor cap - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: 83 L84 Distributor cap
    Michael, You will see a ton of different numbes inside the cap. I think Bill Clupper told us that was a mold number but I forget. Anyhow every cap I have has a different number. As far as gusset goes my D310R and my D310 caps all look alike.
    I have seen some pretty convincing massaged D310 caps where there are no visible scratches unless you use a magnifying glass.
    If you want to clean up a filthy distributor cap the first step is to put it in the dishwasher. Lightly glassbead the contacts and then send out the windows for zincad and you have a decent looking cap.
    • Michael H.
      • January 29, 2008
      • 7477
      Originally posted by John DeGregory (2855)
      Mike, Early in the AM and having trouble understanding your post. D310 caps with the R are quite common. Service replacement low tower caps with the R.
      Have a few of them on my desk right now.
      JD
      JD, it's obvious now that Delco did make short tower caps with the R at some point, maybe years after the original run in the early 60's. I've had a lot of these new/NOS in the box decades ago but never had one with the R.
      • Michael G.
        • November 12, 2008
        • 2158
        #18
        John, thanks for the input. I'm not suggesting that the cap I have was made in 1962-3. I found it in some of my junk and am wondering what the heck it is. From what you guys say, it seems obvious that it is a Delco-made service replacement cap from the late 60's. I'm OK with that explanation.
        Regarding your other question, the service cap and the original seem to be identical (except for the "R"). The "gusset" is not present on recent reproduction caps, but is found on both Delco service parts and original D310's.
        Mike
        1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
        1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
        • John D.
          • December 1, 1979
          • 5507
          #19
          Thanks Michael. Now I know what you are talking about. I never saw a repro Thanks, John
          • William C.
            • May 31, 1975
            • 6037
            #20
            LR indicated Low resistance. We made wire for Chrysler also in the same plant, and Chrysler used a higher resistance spec than GM so all the GM stuff was printed with the TVRS LR logo before it was wound on the takeup reel.
            Bill Clupper #618
            • William C.
              • May 31, 1975
              • 6037
              #21
              I believe the "R" was to indicate registered Patent. Lots of strange government stuff with patent infringement in the late 60's-early 70's (and beyond)
              Bill Clupper #618
              • Michael H.
                • January 29, 2008
                • 7477
                #22
                Thanks Bill.
                • Larry M.
                  • January 1, 2002
                  • 538
                  #23
                  Help a neophyte. I bought a D310 repro non R but it may not be. In another post William Clupper stated that the towers were about 3/8 shorter than a D308/309. The pic Wayne posted certainly shows short towers. Can someone measure the towers and tell me what they get. It will be different if you measure on the OD of the cap or to the inside. I think the simplest is to just set a scale on the side of a plug wire tower closest to the coil wire tower. This single measure would help me know what I have (and maybe help some other folks too). The one I have measures about 3/4 on the outside of the plug wire tower and less than 5/8 on the high side next to the coil wire tower.
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    #24
                    Larry, the #1 tower on a D-310 distributor cap measures .68" from its base, when measured at the forward-most point of the tower in the installed position on the car.
                    Mike
                    • Larry M.
                      • January 1, 2002
                      • 538
                      #25
                      Thanks Mike. I think mine is a 310. The aftermarket I took off is about 3/16 taller and a guy who has an NOS Delco no R unidentified by part number for sale on ebay for $75 measured his towers for me and they are about the same as my aftermarket - not a D310. So in that old post William Clupper meant 3/16 when he wrote 3/8 or there is more variation out there.
