1972 convert engine pad question - NCRS Discussion Boards
  • Joseph U.
    • April 30, 2001
    • 241
    I have just looked at a beautiful red 72 air convert. the engine pad stamping is as follows:
    12sxxxxxx (the last 6 numbers match the vin on the window plate but I don't understand the "1" before the 2S.
    the other number on the block seems to be VD923ckw.
    this car is a 4 speed convert base engine with PS not PB.
    Can anyone help with the decoding of the engine stamping?
    Thanks for the help.
    Joe
  • Joseph U.
    • April 30, 2001
    • 241
    Re: 1972 convert engine pad question
    just found out one of the engine cylinders was re-sleaved several years ago.
    How concerned should I be - car seems to run just fine, does not burn oil and no sign of leakes.
    Thanks again
    Joe
    • Paul O.
      • August 31, 1990
      • 1716
      Joe
      The VIN stamping with 12SXXXXXX is normal for a 1972. The Date and Suffix code should read V0923CKW or Flint Sept 23 day 350CI/300HP 4-speed
      • Michael W.
        • March 31, 1997
        • 4290
        The 1 at the beginning of the VIN derivative is normal for a '72. The other stamp probably reads V0923CKW. That translates to an engine built in the Flint MI engine plant on Sept. 23, base engine with 4 speed trans,
        • Kurt G.
          • April 30, 2005
          • 343
          One other thing, I'm guessing the "2" is, and should be a "Z".
          Kurt Geis
          Chairman, Midway USA Chapter
          Targa Blue 1972, Top Flight and Duntov Award, 2014
          Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
          Arctic White 2013 60th Anniv Special Edition Conv.
          • Jim T.
            • February 28, 1993
            • 5351
            Joe
            1972 Corvette 350 CKW was a 200HP.
            • Joseph U.
              • April 30, 2001
              • 241
              So are is there any significance to these letters and numbers?
              joe
              • Michael D.
                • June 30, 1996
                • 536
                Yes. The engine code and suffix identify the engine. The VIN derivitive stamp identifies the car in which the engine was originally installed.
                • Michael W.
                  • March 31, 1997
                  • 4290
                  No, should be a '2'.
                  • Kurt G.
                    • April 30, 2005
                    • 343
                    Thanks Mike. That's right. I was thinking of something else.
                    Kurt Geis
