Key hole under dash 1959 - NCRS Discussion Boards
  • Stephen B.
    • August 31, 1992
    • 261
    I recently had my 59 judged in Dayton Ohio. I got my first Top Flight, but found that several things weren't quit right. Much to my surprise I was missing the block off plate for the courtesy lamp, and the key hole used for the power top. 8 point deduct ouch. My question, who among you has put the key hole in and what are the most accurate ways of doing so. I want my 8 points back next time.
    Stephen Barrett (215580
    1959 1966 1971
  • Vinnie P.
    Editor NCRS Restorer Magazine
    • May 31, 1990
    • 1571
    Re: Key hole under dash !959
    Stephen...check the Spring 2009 issue of The Restorer...page 50 & 51 two articles on the cutout...Volume 35, #4...if you don't have the magazine you can order the complete CD from the NCRS store
    • Stephen B.
      • August 31, 1992
      • 261
      Thanks Vinnie
      Don't have that issue. how about a quick explanation anyone. How you did it is fine. I have my own ideas, but always interested in others methods.
      • Vinnie P.
        • May 31, 1990
        • 1571
        check your email
        • Donald H.
          • November 2, 2009
          • 2586
          Here's a picture of mine. I cut the hole when I installed the dash, so I was able to do it through the speaker grille opening. Also, my car is a no radio option car. I used a small brass plumping fitting that was the same size as the hole in the fiberglass. I used a pointed grinding stone to sharpen the inside edge of the brass tube. I held a block of wood tight against the underside of the key hole opening and slowly rotated the home made cutting tool. Cut a very clean opening. I then used a xacto knife to trim out the small slot.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
