'78 Vette tach problems. - NCRS Discussion Boards
  • Nickolas C.
    Infrequent User
    • December 15, 2008
    • 2
    The tach has never worked since I have owned the car. Upon examination I found the circuit board damaged and ordered a new one. After installing, tach still doesn't work. Checked filter at rear of engine. Connection was proper at distributor and at end going to wire from fire wall. Disconnected both ends and hooked wire from fire wall direct to tach. Still nothing. Need help - any suggestions?
  • Tom R.
    • June 30, 1993
    • 4102
    Re: '78 Vette tach problems.
    What was the damage to the circuit board? Crushed, burnted out? etc. It is estimated that 90% of time its the board but obviouisly you have moved beyond that guideline.
    It will work without the filter but it sounds like it is not getting power. Is the needle registering anything? Sometime after the introduction, an inline fuse was introduced to protect the board...may have been 1977. I am not sure if it was later moved to the board or still inline for 1978. I'll look at my circuit schematic.
    Finally, did your board come with insulation washers (fiberboard) and were they used? Or, the board should have had no solder around the mounting holes. New boards were shorting out because manufacturers did not understand that putting solder around the holes meant they would short. Than they introduced the fiber washers but did not tell owners to use the washers and why. Manufacturers have adjusted their board design to correct for this but it depends on their source.
    This link is to an article that gets into technical nature of tach boards but not sure it has suggestions for your situation.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Nickolas C.
      Infrequent User
      • December 15, 2008
      • 2
      Thanks for your reply. I ran across a thread posted by John Gardner about the fiberboard washers and tried that last night. It worked. Thanks for your help.
      • Tom R.
        • June 30, 1993
        • 4102
        My 78 is actually sporting one of John's boards. But I'm curious...who did you get your board from? PM me if you wish.
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
