1967 wiper arm adjustment screw - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    I have an original set of wiper arms on my car, but one of the arms is missing that adjustment screw. Does anyone know where I can find one and once one is found, is there a simple way to install it.
    In addition, has anyone come up with a fix that looks original?
    The arms are in pretty good shape.
    Jerry
    Re: 1967 wiper arm adjustment screw
    Jerry
    Jerry -
    It looks like a fairly conventional pan head stainless machine screw; unhook the tension spring, install the screw through the threaded adjuster peg, and re-connect the spring.
      • 6950
      John,Those screws on the arms looks like it may have been peened over the side opposite the screw head.
      • Peter L.
        • May 31, 1983
        • 1930
        The screw is ~0.65+" long installed. It has a short reduced diameter unthread section directly under the screw head that is the length of the main body wall thickness, ~0.03", so the screw floats. This is followed by the threaded section that is the length of the main body width, ~0.55", followed by a reduced diameter unthreaded section that goes thru the other side of the main body & then is peened over. Pete
        • Gerald C.
          • June 30, 1987
          • 1299
          Pete,
          Do you have one of these as mine is missing?
          Jerry
          • Gerald C.
            • June 30, 1987
            • 1299
            John,
            I'm also missing the adjuster peg. Are they available?
            Jerry
              John,
              Jerry
              Jerry -
              I think you want Pete, not me - I don't have wiper parts.
