1968 Carpet Cut Outs - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    For my '68, is it correct that there are co cut outs for the rear bolts/track to sit on? Also for the front, do I understand correctly to cut an 'H' and remove the aft square to have the track end and bolt sit on? Thanks for clarification.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • John C.
    • January 1, 2005
    • 616
    Re: 1968 Carpet Cut Outs
    Bill
    For 1968 I think you will find owners who report no cut outs for the rear track, and owners who do report cut outs. My 1968 doesn't have them.
    The front cut outs are a simple U shape. The tracks sit directly on the fiberglass floor and the flap on the U is used to cover them up.
    See the attached pictures for a look at my 1968.
    John
    • Brian W.
      • September 30, 1990
      • 216
      Just a little off topic but carpet related. I notice in John's first picture there is a trim where the outboard seat belt comes through the carpet. Did all '68's have this trim? I have the chrome piece underneath but haven't seen any trim in this area. The car is a mid December if this makes any difference and if I should have them are they black or carpet color? By the way, there was no carpet in the car when I bought it. Thanks.
      • John C.
        • January 1, 2005
        • 616
        Brian
        Not all 1968 carpets have the grommet for the seat belt to pass through. There doesn't seem to be any rhyme or reason as to which carpets received it and which ones didn't.
        John
        • Brian W.
          • 216
          John:
          Assuming I didn't have the grommet, how is the carpet finished off around the area where the belt would pass through? Is it just a slot cut in the rug or what?
          • John C.
            • January 1, 2005
            • 616
            Brian
            If the carpet doesn't have the grommet, the carpet is cut in the same location for the belt to pass through and left rough.
            John
            • Jack C.
              • September 30, 1992
              • 1090
              I have the grommets on my Jan 22 built 68 if this helps.
              Jack Corso
              1972 Elkhart Green LT-1 Coupe 43,200 miles
              Top Flight 1994, 2018 & 2021
              • Patrick N.
                • March 10, 2008
                • 954
                my March 7 built 68 did not have the grommets.
                  • 15613
                  While people are reporting the grommets or lack of them, it might be wise to consider that the presence, or lack of grommets may have been not only dictated by car serial number, but also carpet color and maybe even manual or automatic transmission -- that conundrum is why the judging manual says, to paraphrase: ... some had them and some did not. For more see page 17 of the 4th edition 1968-69 TIM&JG.
                  • William H.
                    • January 1, 2006
                    • 209
                    What's the consensus on how far the front cut out flap goes back on a '68? Does it go just past the bolt or farther back? Thanks.
                    Bill Hyndman
