I was wondering if there is a procedure to re-key these door locks?
I totaly forgot about this until it was time to put them back in and remembered that the drivers side has to have the key pulled out ever so slightly to work and the passenger side lock doesn't work at all for some reason(both using the ignition key).
I also noticed that the drivers side lock stainless cover is held on with four tabs bent over but the passenger side lock(the one that doesn't work at all) is crimped all the way around so it looks like it's lip was rolled to hold it in place.
Any advice is appreciated.
