Spark plug wires - NCRS Discussion Boards
Spark plug wires
  • Perry M.
    • January 1, 1977
    • 325
    Spark plug wires
    Does anyone know how many feet of Packard 440 wire I should buy to replace my reproduction wires from Electric Life? I found some for $1.00 per foot if I buy 50 feet or $1.30 per foot for 25 feet. Anyone found some for cheaper? This would be for a 63 L84 motor.
    • 6948
    Re: Spark plug wires
    Perry, I can give you the lengths of each wire, #1=49" #2=49" 3=49" 4=45" 5=32" 6=32" 7= 26" 8=26" these lengths are from a lectric limited data sheet I have. I Believe that the original wires from the factory may have varied a little, I can tell you they are a perfect fit at these lengths.( this is a small block)
    • Harry S.
      • July 31, 2002
      • 5321
      Ed, what's the difference between Packard 420 and Packard 440?
      • Gene M.
        • April 1, 1985
        • 4232
        Hi Harry,
        I know the 440 wire is stranded stainless steel. No RFI shielding with 440 wire. I would assume the 420 is something else.
        • Perry M.
          • January 1, 1977
          • 325
          Thanks Ed. That is the info I was looking for.
          • William C.
            • May 31, 1975
            • 6037
            Actually 440 is stranded tin coated copper wires, it is extruded once with an inner insulation that has a high dielectric, then another coat of "rubber" is applied for enhanced weather resistance. There were many variations and all the three digit part numbers were United Motors Service part numbers. Keep in mind use of ANY solid conductor wire in a Corvette will render the radio generally useless.
            Bill Clupper #618
            • Gene M.
              • April 1, 1985
              • 4232
              I guess the tin plate fooled me........thanks Bill
              Oh, and they make the automatic garage door opener on my garage not work too.
              • Ralph S.
                • February 1, 1985
                • 935
                I have a spool of 440 it looks like stranded copper wire core. it has PACKARD 440 USA stamped on it.
                • William C.
                  • May 31, 1975
                  • 6037
                  Look closely, anything that was "rubber" coated was tinned back in the day. The plant that made 440 was the first place I worked after I got out on high school. The actual construction is the tinned copper wire, coated with a Dielectric compound, (extrusion process) then rerun for a second coating of neoprene for protection from the engine compartment fluids. The "535" product was the same as 440 except that after the first coat of insulation, a braid was added between the first and second extrusion, added about 15K volts to the breakdown voltage of the finished wire. 30Kv rating if I remember correctly with the added innerbraid.
                  Bill Clupper #618
