1979 Spark Plug Wires - NCRS Discussion Boards
  • Schanen C.
    • February 1, 2010
    • 122
    Hello All,
    Wich Spark Plug Wire Boots are Correct.
    I have found NOS ones Look Photo and the other are from Lectric Limited.
    They Have Different Boots.
    Especially this from Lectric Limited the boot on the Left Side in the Red Circle.
    Can anyone Help me Please
    Carlo
    • 6960
    Re: 1979 Spark Plug Wires
    Schanen, The lectric limited wires set is correct.sometimes the NOS parts are not always configued like the original parts. Does your car have the plastic ring that retains the wires at the cap end? thats the reason for the lectric limited boot end.
    • Schanen C.
      • February 1, 2010
      • 122
      Hi Edward,
      Yes i have this Plastic Ring,so i know why this Differnce.
      Thanks for the Precise Answer.
      Rgds.
      Carlo
      • William C.
        • May 31, 1975
        • 6037
        The red circled item is the one used with the large diameter HEI with the plastic retainer on the top. THe "knob" on the top of the distributor terminal pushes into the retainer ring and they were shipped as full sets to the Assembly plant. Later production went to shipping individual wires and the I don't know enough about a '79 to know what distributor it uses, but if you know that, you will have the answers as to which set is "more" correct.
        Bill Clupper #618
