65 Radiator Saddle - NCRS Discussion Boards
65 Radiator Saddle
  • Jimmy B.
    • July 31, 1980
    • 584
    65 Radiator Saddle
    Replaced the lower bottom bar in my 65 sbc radiator saddle due to rust. My welder did a great job. Cost was $25.00 and I furnished the reproduction lower bracket. Much to my dismay when I go to mount my pg trans cooler there are no holes there for my mounting bolts. Does anyone have a close up photo of the lower saddle cross bar showing the holes and their placement so I can get these holes drilled out. It looks like I also need the hole placement for the 2 front nose headlight support rod brackets. Thanks in advance. Jimmy Blakely
  • Michael G.
    • December 31, 1996
    • 1251
    Re: 65 Radiator Saddle
    Why not use the old bracket as a templete?
    • Jimmy B.
      • July 31, 1980
      • 584
      Michael, The welder through my old bracket into the scrap heap and it has now been removed from his premises. Thanks for the suggestion though. Jim
