Bench test Headlamps - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4100
    How do you bench test Power Beam or Halogen high beam headlamps with the 9 volt battery. I've done this before but the three terminals I think I need a jumper wire or something. Anyone know of hand?
    I was rummaging some old storage closet and came across these packed away. Probably the easiest is plug them into the car and turn the lights on!
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Terry D.
    • May 31, 1987
    • 2696
    Re: Bench test Headlamps
    Did you mean 12 volts? And yes you need a third wire, one is ground, one will light low beam other will light high beam
    • William L.
      • December 1, 1988
      • 944
      Tom the 3 prong bulb is the Hi/Low bulb. The 2 prong bulb is Hi Beam only.
      You can check your 3 prong bulb with just 2 wires101_1821.jpg by putting a ground wire to the center post then taking your hot and touching it to the right post it should burn low.
      Then you can take the hot and touch it to the left post it should burn brighter than it did before. If only 1 side lights up the bulb is no good.
      Bill Lacy
      1998 Indy Pacecar
      • Tom R.
        • June 30, 1993
        • 4100
        Thanks guys
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
