65 Turn signal flasher HELP - NCRS Discussion Boards
  • Ernest C.
    • July 31, 1991
    • 115
    I have all new wiring harnesses an everything is hooked up and working, My turnsignals however are blinking very fast. I have all new bulbs, and I think it may be the flasher, but I now can't find it. Can anyone tell me where it is located.
    Thank you
  • Jim D.
    • 2883
    Re: 65 Turn signal flasher HELP
    It should be attached to a clip located near the top of the left radio side panel.
    • Ernest C.
      • July 31, 1991
      • 115
      Jim, thank you I found it, but somehow it was higher up near the heater box.
      Thanks again
      • Bob R.
        • June 30, 2002
        • 1595
        The repo bulbs may be different then the original check the part numbers on the bulbs. The incorrect bulb will flash too fast when used with a correct flasher.
