63 fuel pump rebuild - NCRS Discussion Boards
  • Jim C.
    • May 31, 2000
    • 96
    I forgot to note which way the 2 check valves are oriented in the pump housing. Any one be of help ? It is a 4957 pump. Thanks
    Jim Cear
  • Donald H.
    • November 2, 2009
    • 2580
    Re: 63 fuel pump rebuild
    Does this help? This is from a fuel pump rebuild document by Dave Zuberer. I can send you the whole document if you send me your Email address.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Timothy B.
      • April 30, 1983
      • 5186
      Jim,
      Also bec sure to broach the surfaces of the fuel pump on a flat surface with some 220 sandpaper so everything seals nice and tight.
      • Jim C.
        • May 31, 2000
        • 96
        Don that would be a big help. Dadc130@yahoo.com. Thank you !
        Jim Cear
        • John D.
          • December 1, 1979
          • 5507
          Jim, Look in the 63 Shop manual. Page 6M-29.
          Hopefully you are using a rebuilt kit for ethanol. John
