DOT 3 brake fluid requirements? - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    I was told by NCRS judges that DOT 3 brake fluid was required in a vechicle originally equiped with it for points judging. Is this true.
    • 15599
    Re: DOT 3 brake fluid requirements?
    Someone was yanking your chain. Or they are as dumb as a box of rocks -- no offense to any rocks reading this.
    • Brian M.
      • February 1, 1997
      • 1839
      Probably had to do with the wording on the M/C cap.
      • Larry M.
        • January 1, 1992
        • 2691
        And we need to also check for GM-branded Type MS motor oil.
        Larry
        • Michael G.
          • January 1, 1997
          • 1251
          This is a falsehood.....
          • Michael H.
            • January 29, 2008
            • 7477
            Larry
            How about the correct pink anti freeze for 63-64.
            • John M.
              • June 27, 2010
              • 179
              only if its the original DOT 3 from GM then its got to be worth at least 1 additional point.
              • Michael W.
                • April 1, 1997
                • 4290
                Please ask these knowledgeable judges how they test the fluid to see if it's DOT3 and not DOT4 or anything else.
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Easy! Remove the cover and count the dots.
