How to protect bare metal fastners - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    Quite a few fastners on our cars came without a plating or black oxide finish. Seems that bare metal was quite common.
    When restoring these fastners what process do you use and how do you protect them from rusting? Looking for some good ideas from those with experience.
  • Michael G.
    • November 12, 2008
    • 2158
    Re: How to protect bare metal fastners
    Depends on what you are going to do with the car. If its a trailer queen, or your drive it rarely and only in dry weather, a thorough cleaning of all rust, then just an oil dip before assembly will last a long, long time. If your going to drive it in the rain or you live in a very humid area, you can try a satin or flat clear-coat to prevent rust for a while. For what its worth, a flat clear-coat looks very much like plain steel. I wouldn't put paint on the threads, though, as that'll bugger up the assembly clamp-load.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Troy P.
      • February 1, 1989
      • 1284
      Have you ever heard of heating the part and dipping it in oil? Theory is it will suck oil into the pores.
      • Kurt G.
        • April 30, 2005
        • 343
        Heating the part then dipping it in oil will work. One thing I do is use anti-seize compound, the silver stuff. Coat the part in a light film of the compound, let it set for about a half hour then wipe it clean. I don't know how it works on a daily driver, but on my occassional sunny day avoiding water puddles car it works pretty well. Got the trick from a friend down in Dallas.
        Kurt Geis
        Chairman, Midway USA Chapter
        Targa Blue 1972, Top Flight and Duntov Award, 2014
        Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
        Arctic White 2013 60th Anniv Special Edition Conv.
        • Ronald L.
          • October 18, 2009
          • 3248
          The heat and oil dip could change the strength properties, maybe not the right thing to do if the bolts are grade 5 or 8 to begin with, and the process its self is basically an oil quench that will result with a part darkish brown, close to the black oxide which as much as I write it, no one gets the idea it does not provide corrosion protection. Black oxide is rust, the colors of which range from black to umber to orange and red, depending upon how its combined with oxygen.
          • Rich G.
            • August 31, 2002
            • 1405
            Corrosion X is a liquid product that works well, but may have to be re-applied once in a while. It's electric friendly so it can be sprayed or brushed without worry about wires and switches and works great on battery terminals.
            Rich
            • Troy P.
              • February 1, 1989
              • 1284
              Worth a try. Any other ideas out there?
              • Troy P.
                • February 1, 1989
                • 1284
                So you are saying black oxide is not a corrosion portection. Then why did they use it?
                • Chris S.
                  • January 1, 2000
                  • 1068
                  Sharkskin and RPM
                  there are others out there
                  1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                  Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                  1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                  1957 Corvette - FI 3 sp - Black and Silver
                  • Steven B.
                    • June 30, 1982
                    • 4011
                    Troy, Gibbs Brand is excellent for protecting non-ferrous and ferrous metals. I have used it for years and found nothing better. Steve
                    • Glen C.
                      • November 1, 1985
                      • 193
                      I've been using Gibbs for a couple years now. Search Gibbs on this site for more information.
                      • Michael G.
                        • November 12, 2008
                        • 2158
                        Black oxide was purely decorative, it provides no corrosion protection.
                        Many here think that the finish on GM's black (actually dark grey) fasteners of the sixties was black oxide. The vast majority were not black oxide, usually they were zinc phosphate with an oil dip. The phosphate was there to absorb the oil, the oil was the corrosion preventative. Oil-coated steel fasteners, without phosphate to hold the oil, will rust quickly when exposed to water, no matter what magic oil you use.
                        Mike
                        • Gene M.
                          • April 1, 1985
                          • 4233
                          For the trailer queens rub the bare metal down with STP oil treatment it lasts for years. But be advised it makes handling the bolt to start them by hand a slippery task!
                            Troy -
                            They didn't - for all practical purposes, no black oxide-finished fasteners were used on Corvettes. Most fasteners that folks think are black oxide are actually phosphate and oil.
                            • Donald H.
                              • November 2, 2009
                              • 2589
                              Troy -
                              John, is the phosphate you mention the zinc or manganese phosphate treatment or Parkerizing? I just ordered some manganese phosphate to try to Parkerizing some bolts.
                              Don Harris
                              Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
