Can someone explain the clutch & pedal adjustment for my M21? I'm either missing the obvious or some parts are out of whack.
I don't seem to have any trouble shifting while driving. The problem is when shifting into reverse. I'll be moving forward and come to a stop, clutch pressed to the floor, I'll bring the shifter out of 1st (or any forward gear) and put it in neutral, wait a few seconds and then slide it into reverse. When I go into reverse, I can feel the "reverse shaft" (not sure if that is the correct terminology) still spinning, so it will grind a bit to get into reverse. (Grind may be too harsh of a word, but a noise none the less) I've tried leaving the shifter in neutral for 10-15 seconds before going into reverse, same noise. You can feel (but not hear) something spinning.
I can start the car with the clutch pressed to the floor. While still stationary, I move the shifter out of reverse and into neutral, I'll then start releasing the clutch pedal, you can hear the clutch assy. engage and start whirring about half pedal travel. Push the clutch in and the whirring stops, move it into reverse and the reverse shaft is moving.
I also do not have any free play on the clutch pedal as described in the AIM.
Am I missing something in the adjustment or is the clutch/pressure plate/bearing out of whack so that no adjustment will work?
TIA,
Mike
TIA,
Mike
