Transistor Ignition coil - NCRS Discussion Boards
  • Ralph S.
    • February 1, 1985
    • 935
    I have a coil 1115207 D514 Brass terminals studs, there a no numbers embossed on it. is there any value to it. it is in a Delco box
  • Dave S.
    • August 31, 1992
    • 2930
    Re: Transistor Ignition coil
    Ralph,
    It is good for any driver car w/ T.I. I would say 50 to 75 bucks give or take.
    • Wayne M.
      • March 1, 1980
      • 6414
      Is this one of those later GM service units with the part # stencilled in white on it ? I remember ordering a '207' at the local GM dealer in the early '80s, and when I opened the box, immediately returned it. I can't recall if it had the Delco sticker, and if it did, whether it was the original '60s style with foil on a paper adhesive backing.
      • Ralph S.
        • February 1, 1985
        • 935
        Wayne, yes it is as you describe, it does have the transistor ignition sticker on it. i did order it in the early eighties.
