67 parking brake handle slider - NCRS Discussion Boards
  • Greg C.
    • February 5, 2013
    • 29
    Hi..Im doing a parking brake console restoration and is it correct that when you pull the handle up you will see a hole because you have to trim the black flexible "slider" so the handle will retract? Seems odd...yet before posting this I inspected a couple of cars and one had the hole...one didnt. Is there a "trick" to making this work without cutting so much off the slider you end up with a hole when the parking brake handle is pulled up?...thanks,Greg
  • Al R.
    • June 30, 1988
    • 687
    Re: 67 parking brake handle slider
    Greg, my original with PW has the hole as you describe when the handle is pulled up. Unsightly, but that's the way they came.
