Can someone post a pic of a 4346 stamp on an original long screw fuel pump for 56-57 - NCRS Discussion Boards
  • Andrew N.
    • November 16, 2012
    • 15
    Title says it all, I've only seen two and they were both slightly different. One has the 4346 stamp on the seam and the other is stamped below it. Both also had a slightly different number font. Any other things to watch for would be appreciated.
  • David S.
    • December 1, 1982
    • 310
    Re: Can someone post a pic of a 4346 stamp on an original long screw fuel pump for 56
    Hi Andrew, I have attached a few pictures of the fuel pump from my 5 star bowtie car. I have had to remove the pump after bowtie judging for a rebuild because it finally failed. It is now back on the car. Let me know if you need any more info. I have recently purchased another unrestored 57 with a real pump that I will get some pictures of Dave
    • David S.
      • December 1, 1982
      • 310
      Andrew here are a few picture from another original 4346 pump from another unrestored car I recently purchased. Dave
      • Andrew N.
        • November 16, 2012
        • 15
        Dave, Thanks for the pictures. Is it correct to have the number 1538354 embossed on the side?
        • David S.
          • December 1, 1982
          • 310
          Andrew no problem seeing the # 1538354. I have attached another picture Dave
          • Daniel R.
            • July 31, 1981
            • 8
            Dave,
            what markings/letters are on the fuel pump bolts?
            • David S.
              • December 1, 1982
              • 310
              Hi Dan, Pump Bolts have TR head markings.Dave
              • Gary C.
                Administrator
                • October 1, 1982
                • 17681
                Dave, tell Dan the head and thread size of the 4 bolts. Gary....
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • David S.
                  • December 1, 1982
                  • 310
                  Dan 9/16 hex bolt with TR logos I would guess 3/8thbolt but I am not sure of the thread. I have them all back in place . I may have a chance to remove one to check after the New England Regional. Dave
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17681
                    Dave, aren't the two upper fuel pump bolts 1/2" head (wrench size) with 3/8" thread? Gary....
                    Last edited by Gary C.; May 14, 2013, 05:35 PM. Reason: correct thread size to 3/8"
                    NCRS Texas Chapter
