64 Power Brake Master Cylinders - NCRS Discussion Boards
  • Michael D.
    Infrequent User
    • November 1, 1986
    • 25
    The new judging manual states that the master cylinder on power brake car has a MDDY code on the underside. The non Power Brake cylinder has a Julian date, I have seen about 30 of them for the last year and have not seen one with the MDDY code, all of them have Julian dates. Anyone know for sure which is correct.
    Mike
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 64 Power Brake Master Cylinders
    Mike,
    First of all why would you assume that the new judging manual be correct? Both are the same casting 5464264 and 7/8" bore. Both the power and non-power came from the same casting. The power has a bleed screw because it is tilted and the non-power does not tilt. Why would one be a julian and the other not when they were cast in the same plant in the same molds on the same day?
    JR
    • Michael D.
      Infrequent User
      • November 1, 1986
      • 25
      Thanks Joe, all along I knew your statement was correct, I guess I just wanted someone else to agree with me.
      thanks again
      Mike
      • John R.
        • November 1, 2005
        • 433
        I agree with you. I have seen Julian dating on power brake master cylinders. Have one out of a 64 that shows 337.
        • Mike M.
          • May 31, 1974
          • 8408
          i just happen to have three 64 MC's currently residing on my work bench, a pair that are off PB 64's and a single one off a non-PB 64. all three have julian date codes.mike
          • Michael H.
            • January 29, 2008
            • 7477
            Originally posted by Joe Ray (1011)
            Mike,
            JR
            JR,
            Keep that up and you could get a 99 year suspension like I did.
            • Alan D.
              • January 1, 2005
              • 2054
              My original 64 power MC is julian dated 337. So has anyone seen an original, on car, dated with MDDY code?
              • Timothy B.
                • April 30, 1983
                • 5202
                Originally posted by Michael Hanson (4067)
                JR,
                So how old are you really, Mike? :-)
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Reduced sentence and early release for good behavior around here.
