L84 fuel system - NCRS Discussion Boards
L84 fuel system
  • Michael G.
    • November 12, 2008
    • 2158
    L84 fuel system
    As we go into the hotter months, I thought it might be a good idea to post this before FI owners start to see the typical problems. About a year ago, I altered my 63 L84 engine plumbing to try to cool the fuel. After making the changes and driving the car several thousand miles, using any old fuel that was available, I've found that fuel percolation is no longer a problem. The car runs fine, even when its hot outside (90+), even with 10% ethanol pump gas. No more $8 a gallon racing fuel.
    The changes were easy, cheap and 100% quickly reversible. Here's what I did. 1) I disconnected the fuel line from the fuel meter inlet and slipped a 3/4 ID tube made of fiberglass insulation over the whole length of the tube. 2) I removed the filter bracket and wrapped the filter with fiberglass cloth with foil backing 3) I disconnect the fuel filter from the front fuel line and slipped a wrap of fold backed fiberglass over the whole length, down to the pump, 4) I wrapped the lower fuel line from under the battery tray to the fuel pump with foil backed tape. 5) I slipped a 6" x 8" foil backed fiberglass cloth under the plenum.
    The whole thing took maybe an hour and now my idle sits steady, right about 800 RPM at idle, even after prolonged driving. Here are some pics:
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12883
    Re: L84 fuel system
    The changes were easy, cheap and 100% quickly reversible. Here's what I did. 1) I disconnected the fuel line from the fuel meter inlet and slipped a 3/4 ID tube made of fiberglass insulation over the whole length of the tube. 2) I removed the filter bracket and wrapped the filter with fiberglass cloth with foil backing 3) I disconnect the fuel filter from the from fuel line and slipped a wrap of fold backed fiberglass over the whole length of the fuel line, 4) I wrapped the lower fuel line from under the battery tray to the fuel pump with foil backed tape. 5) I slipped a 6" x 8" foil backed fiberglass cloth under the plenum.
    [ATTACH=CONFIG]46378[/ATTACH][ATTACH=CONFIG]46380[/ATTACH][ATTACH=CONFIG]46381[/ATTACH]
    good tips, I'll keep them handy for when I'm going to start my car for the first time later this year...
    Rob.
    NCRS Software Developer
    • Michael G.
      • November 12, 2008
      • 2158
      Re: L84 fuel system
      Rob, are you talking about the unrestored L84 engine you posted pics of here a couple of years ago?
      Mike
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12883
        Re: L84 fuel system
        yes indeed!
        Rob.
        • John D.
          • December 1, 1979
          • 5507
          Re: L84 fuel system
          Good job Mike. Now let me report on the 58 to 61 also the 62 FI units. Seems that the fuel line that goes from the engine fuel pump to the fuel filter is hugging the valve cover and in some cases hitting the valve cover. Seems that most of the repro fuel lines are incorrectly bent. What happens is the fuel is boiling or very hot before it even reaches the FI unit!!!
          The original fuel lines are at least an 1" or more up off the valve cover. Those lines are typical parallel to the valve cover. And the originals are not hitting the valve cover on the radiator side or at the firewall side like a typical repro.
          Your job is to alter those lines or have a new one fabricated. Then insulate it well and you should notice an improvement.
          How about someone here posting some pics of a known original fuel line for a 58 to 62 FI car. JD
          • Michael G.
            • November 12, 2008
            • 2158
            Re: L84 fuel system
            Rob, it looks a bit better than it did:
            Nice job.
            John thanks for the comments, I can't help you much with pre c2 fuelies.
            Mike
            • John S.
              • May 4, 2008
              • 427
              Re: L84 fuel system
              Mike,
              nice job! Looked a little rough originally huh? Saving this post for if and when I have problems with the 65 this summer in So. Cal. Next test is a local car show this Saturday. Temps supposed to be around 90 degrees. Place is less then 10 minutes away, so I may be driving out of the way to get there.
              John Seeley
              67 Black/Teal
              300 hp 3 speed coupe
              65 Maroon/Black
              35k mile Fuelie coupe
              • Michael G.
                • November 12, 2008
                • 2158
                Re: L84 fuel system
                John, sorry I didn't explain, the pic of the rusty engine that I posted is not my engine, its a pic of Rob's engine two years ago, before restoration (the after is shown in post #4)
                Mike
                • Charles M.
                  • November 1, 1979
                  • 33
                  Re: L84 fuel system
                  Mike, where did you get the fiberglass pipe insulation you used on the lines from the pump to fuel meter? My 61 FI has always had vapor lock issues unless I use av gas.
                  Thanks Chuck M.
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    Re: L84 fuel system
                    Chuck, most auto parts stores carry similar shielding. One web site that carries most of the available heat shielding materials is:
                    Heatshield Products offers customized thermal management products for Automotive, Heavy Duty Industrial, Military, and Home DIY. heat shield technology that reduces radiant exhaust heat while maximizing engine performance and reliability. %
                    Next time I take the fuel system apart, I'm going to use the foil backed reflective tubing (that I used on the front fuel line) on all of the lines, as it reflects about 90% of the radiant heat. IMO the most important line to insulate well is the lower one, since it is very close to the exhaust manifold and normally gets very hot (160 F+). I think this line heats the fuel and it never gets cool again.
                    Mike
                    • Charles M.
                      • November 1, 1979
                      • 33
                      Re: L84 fuel system
                      Thanks for the info Mike, will give it a try. Av gas is expensive here in Fla., $6.00+ a gallon!
                      Chuck
