ammeter pegging - NCRS Discussion Boards
ammeter pegging
  • Don W.
    • September 30, 1997
    • 492
    ammeter pegging
    I was out for a long drive on Sunday. My ammeter needle would run at zero and then snap to right to +40 several times per minute. Any thoughts or normal? thanks...Don
  • Jim T.
    • March 1, 1993
    • 5351
    Re: ammeter pegging
    Is your car a 68 or 69? 1968 was the last Corvette with external voltage regulator mounted on fender well and 1969 first year for voltage regulator in the alternator? On the rear of a 1969 alternator there is a place you can touch a tab with a screwdriver and verify the alternator is working. This function bypasses the regulation of the internal voltage regulator.
    The 69 voltage regulator is not difficult to replace. A toothpick or something similiar will hold the brushes retracted.
    • Don W.
      • 492
      Re: ammeter pegging
      Mine is a '69 and everything seems to be working fine. The battery stays charged and drove it for 3 hours on Sunday...Don
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Re: ammeter pegging
        The meter is actually a current sensing sensitive voltmeter. It senses the differential voltage between the battery voltage at the starter and the load out at the horn relay buss bar.
        It's possible that you have a defective meter, but it's also possible that your connections at the source and load points have corrosion and are connecting intermittently and causing your meter to deflect intermittently. Check your connections and clean if needed. The wiring passes through a body connector so possible corrosion there too. I'm not sure where that connector is on a '69.
        • Paul J.
          • September 9, 2008
          • 2091
          Re: ammeter pegging
          Don, it could also be a short somewhere in the wiring, but first I would check the voltage regulator.
          Paul
