1972 350 spark plugs - NCRS Discussion Boards
  • Martin Z.
    Infrequent User
    • January 1, 1998
    • 26
    What are correct AC Delco replacement spark plugs for a 1972 350 L48?
    • 43247
    Re: 1972 350 spark plugs
    Martin------
    AC R-44T, aka GM #5613867.
    • Martin Z.
      Infrequent User
      • January 1, 1998
      • 26
      Thanks Joe!
        • 11668
        Based on the AC Delco website as well as previous recommendations and trials I use the 45TS in my 1972s.
          • 43247
          Patrick-----
          The R-45TS can be used and might even be better for most driving conditions. However, it's not the plug originally specified.
            • 11668
            Patrick-----
            Nope, though I think it was for 1971 IIRC. I know that they originally had different plugs than the 72.
            Same motor, so interesting change.
            • Martin Z.
              Infrequent User
              • January 1, 1998
              • 26
              Patrick,
              What is the gap setting for the R45TS? THANKS
              • Kurt G.
                • April 30, 2005
                • 343
                .035 gap. The 45 is a little hotter plug. If you run it AND run regular gas you are more apt to get pinging.
                Kurt Geis
                Chairman, Midway USA Chapter
                Targa Blue 1972, Top Flight and Duntov Award, 2014
                Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                Arctic White 2013 60th Anniv Special Edition Conv.
                  • 11668
                  Who runs regular gas in a Corvette?
                    • 43247
                    Patrick-----
                    1971 L-48 specified the same R-44T as 1972. For 1971, though, the LT-1 called for the R-43T whereas 1972 LT-1 called for the same R-44T as L-48.
                    Addendum-----
                    I've found some conflicting information for 1971 L-48. GM information says that the R-44T was specified. Delco information says the R-44TS.
                      • 11668
                      Originally posted by Michael Ward (29001)
                      People with stock smog engines that know that anything higher than 87 octane is a waste of money. That's what the cars were built to run on.
                      Cheap insurance if you ask me.
                        • 11668
                        Sorry Mike, you're not going to goad me into one of your arguments.
                        Have a good day.
