64 to 65 trailing arm interchange? - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    Is it posible to interchange 64 drum brake and 65 disc brake trailing arms with modification? What modification is necessary? Are they the same length?
    • 43277
    Re: 64 to 65 trailing arm interchange?
    Stan------
    The last set of SERVICE trailing arms available from GM were the same for both drum and disc brake applications. However, I just don't recall what the original differences were. It might have had something to do with the parking brake or brake line brackets.
      Stan -
      They're the same length, but the '65-up trailing arms have a separate pad welded on the top surface to contact the jounce bumper, which was moved inboard from its original '63-'64 location outboard of the frame with the advent of disc brakes in '65, and there are several other minor bracket differences. Photo below is a LH '65-up arm.
      • Wayne M.
        • March 1, 1980
        • 6414
        Stan -
        [ATTACH=CONFIG]46315[/ATTACH]
        Here's another view of the pad and you can see the off-set jounce rubber bumper above and in line with the trailing arm pad, attached to the frame.
        c
        • Stan E.
          • April 30, 1991
          • 383
          Thanks everyone. I'm trying to solve an alignment problem and I remember changing one and but having to remove a bracket. This must not be the problem. Thanks again! stan 19259
