I completed my standard to power brake conversion Friday night, and am pleased with the end result but not the brake bleeding process I had to go through. Hence this post.
I have a Motive Power Bleeder and used it successfully in the past to flush and refill with DOT 4 brake fluid when replacing the master cylinder 3 years ago.
On my power brake conversion I decided to go with DOT 5 since everything would be new. To bleed, after bench bleeding the master cylinder, I hooked up the Motive Power Bleeder and it got fluid throughout the brake system easily--first time in my life that I ever filled a completely dry, new brake system.
All the big air bubbles were gone per normal (my rule of thumb is to run at least a pint through each bleeder screw, intermittantly closing off the bleeder when it looks clear/no air and beating on the caliper with a rubber mallet to force more air up and out).
The problem was that each time I re-opened the bleeder screw, I kept seeing a very short burst of tiny, tiny air bubbles followed by clear with no air fluid. Close the bleeder, beat, repeat and tiny bubbles again and again. The Motive Power Bleeder was pressured at 5 psi down to zero, which is barely gravity bleeding flow.
No matter what I did, the tiny air bubbles on opening the bleeder never stopped while using the Motive Power Bleeder and I used a ton of brake fluid (4 liters). I used about 2 liters just on the right rear caliper alone before deciding to move on to the other 3, and then go back to the right rear where I started. Same thing everywhere--tiny bubbles (and if Don Ho were still alive, I'd like to shoot him dead
After using up the 4 liters of DOT 5 brake fluid I bought from CSSB and going to NAPA to buy more, I figured I had to do something else.
Having no better ideas, I switched to gravity bleeding and then finished with the two-man old fashioned way. It worked--saw the tiny bubbles at the start of the two-man cycle at each caliper and then none. I'm not happy it came to having to enlist the aid of my neighbor to get my brake system bled.
My question is this: Has anyone successfully used a Motive Power bleeder with DOT 5 brake fluid, and if yes, how did you do it differently than I?
I knew to leave the DOT 5 brake fluid sit unmolested--mine came mail order from CSSB, and I unpacked and it sat in the bottles for 3 weeks while I was tearing apart and re-installing all new brake lines, ect...
I then filled the Motive Power Bleeder pouring as slowly and smoothly as possible and let the fluid sit in the bottle unpressured for hours. Used low pressure--with DOT 4 I always start at 10 psi, and this time with DOT 5, I used less than 5 psi which basically was enough pressure to keep the the master cylinder filled and the outflow at the bleeders was about what gravity bleeding produced.
In case I have to do some additional bleeding if more air works its way out of suspension in the fluid, I'd like to do that with the Motive Power Bleeder so as to not inconvenience my neighbor any further (and he got paid a case of beer for helping me out with the two man bleeding to get my car back on the road--I just prefer not to bother my neighbors with my car projects).
Tips, tricks, and advice appreciated from those who have used the Motive Power bleeder successfully with DOT 5 brake fluid.
).After using up the 4 liters of DOT 5 brake fluid I bought from CSSB and going to NAPA to buy more, I figured I had to do something else.
