Final primer - Color - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    Hey all ...
    what is the final primer color on a 1969 C3??
    Thanks -
    Bill
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Final primer - Color
    Can't say for sure but I'll bet a dollar to a dog turd it is the same Dupont lacquer sealer used on midyears. Kind of a semi dark grey.
    • Ron G.
      • December 1, 1984
      • 866
      Not an expert on paint, but I say it was red. If you look under original paint cars on the edges or at the bottom of door edges or the very lower part of door jams where it the rocker moulding is mounted, it is not uncommon to see red primer where they missed probably because the painter was too lazy to bend down or did not think it was important enough to cover that area entirley.
      "SOLID LIFTERS MATTER"
      • Wayne W.
        • April 30, 1982
        • 3605
        Red oxide. May have various coverage of some gray sealer.
        • Mike M.
          • May 31, 1974
          • 8408
          i just finished stripping the original paint off a 64. from the outside in, riverside red, dark grey sealer(very thin coat compared to there red oxide primer in direct contsact with the fiberglass panels). of interest was the thickness of red oxide on pass side vs its thickness on drivers side. it took three coats of capt lee paint remover to strip tthe drivers side to bare glass and 6 to 7 applications of the captain to get to glass on pass side. i assume one of the primer applicators( there were a pair of painters on the st louis line) was a newbie, the other a veteren.mike
          • Bill C.
            • July 15, 2007
            • 904
            thanks for the feedback -
            I thought the last coat was red oxide, but not sure.
            The only thing that makes me wonder though - my 72 was a one owner car with factory lacquer on it. I personally DA'd the paint off the car and for the life of me don't
            remember any red oxide, but rather a dark gray/black primer.
            Is there any chance that the primers may have changed from year to year?
            I do remember red oxide on a very original 66 coupe....
            Just want to be sure I get this correct while restoring the 69 coupe I am purchasing.
            Thanks as always -
            Bill
            • Wayne W.
              • April 30, 1982
              • 3605
              There was a change in later years as they switched to SMC panels. I don't remember exactly when. But 69 is what you asked about and red oxide is correct for that.
              • Jeff P.
                • 799
                I can see Red Oxide in areas of my 68 Coupe.
                68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                2014 Arctic White Z51 Vert. (Wifes)
                • Steve W.
                  • March 1, 2002
                  • 78
                  I can see factory Red Oxide on early and late 68 Coupe.
                  • Patrick N.
                    • March 10, 2008
                    • 954
                    Red oxide on my March 68 - I was surprised at how much over-spray of red oxide was in the interior- floors and sides of the transmission tunnel were fairly well covered with a good amount of Lemans Blue on the floors stopping at the transmission tunnel. The removable hardtop had a very thick layer of Red Oxide compared to the body it seems.
                      • 15632
                      On my 1970, where the paint is thin, red oxide is showing. I really have to get that thing out for John Ballard to see.
                      • Mark D.
                        1984-96 Team Leader
                        • June 30, 1988
                        • 2168
                        "Real deal...no issues"
                        Kramden
                          • 15632
                          I know what he will say. I just want to hear how he says it.
                          • Patrick B.
                            • August 31, 1985
                            • 2012
                            I stripped the factory lacquer off a late 70 car. The doors were actually white SMC and the rest of the car was regular grey polyester fiberglass. It had red primer that I wet sanded off after taking the lacquer and most of the grey sealer/primer off with chemical stripper. This must have been the introduction of SMC parts. I don't know if all 70's used SMC doors.
                            • Bill C.
                              • July 15, 2007
                              • 904
                              thanks for all the info ....
                              greatly appreciated!
                              Bill
