54 rough idle - NCRS Discussion Boards
54 rough idle
  • Guy M.
    • November 1, 1993
    • 500
    54 rough idle
    My chasis engine is running a bit rough at idle and has a bit of backfire when on a hard accel. Will these engines run with the distributer off a tooth? Had it at TDC and the rotor points to #1. The vacuume line to wiper motor is open. Runs worse if closed. Carbs appear to be working good. All cylinders are firing as I checked each by removing wires. It really seems like timing is the issue. The backfire (pop) is on the right side Any advice? Thanks again!
    • 6960
    Re: 54 rough idle
    Guy, have you check the smiple things like dwell, or set the point gap, set the timing with a timing light, carb. mixture. if there still a problem I would suspect a vacuum leak,if you cup your hand and hold it over one of the carb.s ( not completly leave some room for some air to get by) see if it smooths out.If it does, start looking for a vacuum leak.
    • Cathy S.
      • August 31, 2003
      • 293
      Re: 54 rough idle
      Syncing the carbs really smoothed mine out.
      • Chris S.
        • January 1, 2000
        • 1068
        Re: 54 rough idle
        sound like your off a tooth
        if it runs worse.... with the wiper switch open - meaning it is running wayyyyyy rich....
        something is not right
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Chris S.
          • January 1, 2000
          • 1068
          Re: 54 rough idle
          Is the timing pointer lined up with the "ball" on the flywheel at # 1 TDC
          should be dead on
          rotor at #1
          #1 piston at TDC
          • Guy M.
            • November 1, 1993
            • 500
            Re: 54 rough idle
            Ill start with moving the distributer one tooth in either direction to narrow down the timing issue. The dwell is ok. It probably is running rich as the plugs are pretty black. Stumbles more with the wiper line plugged, not sure what that means. Thanks for all the help.
            • Timothy B.
              • April 30, 1983
              • 5202
              Re: 54 rough idle
              Guy,
              I don't Know much about how the wipers work on a 54 but that's a vacuum leak with the line open. If you plug the line and the engine runs bad it's flooding. Can you lean the carburetors, also, the spark plugs are probably soot fouled by now so you may have two issues at this point.
              • Cathy S.
                • August 31, 2003
                • 293
                Re: 54 rough idle
                Also if it stumbling the vacuum advance could be inop.
                  • 6960
                  Re: 54 rough idle
                  Guy, if the spark plugs are black you have excessive fuel be feed into engine, Have you looked into carb. while engine is running to make sure you don't see fuel dripping into engine while cars is running?heavy float will cause this or float level thats to high.
