Hi guys (& ladies, too),
My '65 convertible vent window rubber seals are beginning to show cracks from age at the bottom and corner. I would like to replace them without removing the door panels and taking out the entire assembly. Is this possible, or is this the one weatherstripping piece on a C2 that isn't easy to replace (other than the windshield)? Can someone give me the easiest "step-by-step" procedure to replace these rubber seals? The vent window mechanisms otherwise work very well... I'm just not lovin' the cracks. FYI, I also posted on the CF for other opinions on my options. I want to confirm the easiest procedure for this project. I understand that the rubber seal would have to be cut at the "T" pivot on either the inside or outside if the vent window assembly isn't removed from the door. Any suggestions?
Thank you,
Roger (50141)
Thank you,
Roger (50141)
. I will have to take it slow and keep my fingers crossed.
, Roger (50141)
